I changed the plugs thinking it might be skipping a little. They needed to be changed, but they weren’t terrible. No oil residue or built up carbon, so I assume there is no valve leaks or compression problems. Gas filter in fairly new and it's not acting as if the fuel pump is going bad.
One other thing I've noticed, when idling, the tachometer use to sit around 750-850 and now seems to rev back and forth between that and about 300 or 400 every second or two.
Ideas?
thanks
SPONSORED LINKS
Tuesday, July 28th, 2009 AT 10:58 AM
