1991 suburban stalls under load
TIMJETS
1991 3/4 ton 350, 134k new distributor(prev. ownew) coil, alt, plugs , fuel filter. Always starts fine, runs a bit sluggish until warms up, no stalling. After driving 20-30 min and shifting to reverse to back up, always stalls, or if I leave in drive and turn wheel it stalls. Always starts right up again. If I let it sit a few minutes, no stalling even with load. Has mechanics stumped. Occasionally will miss(not stall)after driving for 45 min. Also, engine seems to run about 75% efficiency, occasionally will run amazing, only for a day or so. No trouble codes at all. Vacuum good, idle control valve, neutral switch good. Egr seems to work fine. Tranny completely rebuilt w/new sensors , had problem before tranny work also. Thanks, Tim
Mar 13, 2007 at 4:44 AM
LVM76
  • 6 POSTS
Have the same problem on backup or hard steering at a stop. Never could solve the problem. Although after I replaced plugs/cap/rotor things got better and it stalled less.. better airfilter was also part of the tuneup.
Fuel pressure might be the problem.. as your car gets older fuel pressure will drop just enough so that extra load on your engine (turning the steering at a stop, or throwing it in reverse fast) will cause the fuel pressure to drop just enough to cause a stall.
Just a guess.
Mar 18, 2007 at 12:22 PM
TIMJETS
ivm76: Thanks for your help, I am replacing vacuum hoses first(original 1991), will let you know :)
Mar 20, 2007 at 3:42 AM
LVM76
  • 6 POSTS
vaccum leaks would cause idle to increase.. so I wouldn't think that tighnening up your vaccum system would help..
Just try removing a vaccum line.. like your MAP. you'll probably stall less at sealevel- but overall performance will suffer as barometric pressure changes.
have a 1990 2500 4x4.. It seems to stall the most on hot days or at high altitude. My bet is on the fuel pressure , most likely the fuel pump loosing its power. Havnt hooked up a fuel pressure meter yet. but will try it shortly and let you know.
Mar 20, 2007 at 2:04 PM
RLIGHT
See if you have a vacuum leak at the base of your throttle body. You might need a new gasket.
Apr 11, 2007 at 3:01 PM
