1983 Chevy Suburban Diesal Leak
COLE79
Other Category problem
1983 Chevy Suburban Four Wheel Drive Automatic 265,00 miles
This truck has a lot of miles on it. It started leaking some fuel from the front driver side of the vehicle. I haven't gotten a chance to investigate because of the cold weather. It only drips when running and when idling. Any ideas of where and what part might need to be replaced?
Thank you,
Matt Cole
mpcole@oppd.com
Jan 6, 2008 at 6:22 PM
  • 31,937 POSTS
Hi there,
You will have to get in and give it a good wash down, run the engine and inspect for the leak, it may be as simple as a loose fuel line or as complex as a leaking injector pump, you will have to Wash down and inspect it. report back if you locate the leak and are unsure as what to do next.
Mark (mhpautos)
Jan 6, 2008 at 7:08 PM
