wind noise 2006 Silverado 2500 HD
2006 CHEVROLET SILVERADO
1DDAY
I have wind noise that sounds like sand hitting the passenger side wind shield. This happends at freeway speeds. Any suggestions?
Thanks, Dan
Apr 15, 2007 at 3:56 AM
4WDBEAL
I have a 2003 Silverado that had the same issue. Mine only did it at highway speeds, not in town. Tried having someone else drive while I rolled down the window, feeling around to see if I could get it to stop. No luck, could not hear it with the window down. After further inspection, I found that the black vent shroud at the bottom of the windshield (shroud that your radio antennae goes through) was riding the windshield at high speeds. Not enough wind speed in town to get it to hit the windshield. Took a file and blended the corner off of the shroud, enough clearance to not hit going down the highway. Problem solved, no more sand hitting the windshield noise. Hope this helps.
May 3, 2007 at 7:34 PM
JOESGARAGE
I've had the windsheid poping noise myself, and others on different fourms had too. The molding on the windshield was vibraiting(a-pillar molding) some used clear RTV under it to hold it down, I used black.
Steve
May 8, 2007 at 10:54 AM
BROWNJP2
  • 5 POSTS
This may sound stupid but do you have a bug sheild. I had one on mine ant above 60mph heard wind took it off and it stoped
May 31, 2007 at 8:34 AM
