2000 Chevy Silverado Hard Start
DSTEPH1
I have a 2000 Chevy Silverado 1500 5.3L automatic. It is a 2wd 3dr. It has 90000 miles on it.
The battery is good. The alternator is good. The starter is working. I have replaced the fuel filter. It will start after pumping the gas. I can shut it off and it will start immediately every time. If it sits it will take several tries to restart by pumping the gas.
I suspect the fuel pump, costly. Is there any other ideas as to the problem. I have only gone through 2 sets of tires and one battery in 7 years. Never had any problems before.
Appreciate any ideas.
Sep 4, 2007 at 8:09 AM
  • 75,988 POSTS
[quote:8f4165011b="dsteph1"]I have a 2000 Chevy Silverado 1500 5.3L automatic. It is a 2wd 3dr. It has 90000 miles on it.
Appreciate any ideas.[/quote:8f4165011b]
Check the fuel pressure-could be a FPR/PUMP/leaking injectors.
Sep 4, 2007 at 8:17 AM
  • 75,988 POSTS
You need a fuel pressure gauge or try this pinch off the return line and see what happens.
Sep 4, 2007 at 8:45 AM
Suggested Repair
Check fuel pressure with a gauge. A weak fuel pump, faulty fuel pressure regulator, or leaking injectors may be the cause. Pinching the return line can help isolate a regulator problem.
Conversation Summary
The owner of a 2000 Chevy Silverado 1500 reports hard starting after the truck sits, although it starts after pumping the accelerator and restarts immediately if shut off. The battery, alternator, starter, and fuel filter have already been checked or replaced. The expert recommends checking fuel pressure, which could point to the fuel pressure regulator, fuel pump, or leaking injectors, using a gauge or by pinching the return line.
