1997 Chevy Silverado No Fuel Pump Power
TONYDANIELS
  • 6 POSTS
97 Chevy Silverado truck, 75,000 miles, V8 305 vorec . Replaced fuel pump in tank (new), replaced fuel pump relay switch, replace fuse, check wiring and okay, ground wire is okay, but I still do not get no humming in the fuel tank, still does not start. It sems there is no power to the fuel pump tank. I ran out of ideas. What can I do.
The truck was running okay and suddenly stopped and had to tow home.
Sep 8, 2007 at 12:57 PM
  • 75,988 POSTS
[quote:8cd0fc04ef="tonydaniels"]97 Chevy Silverado truck, 75,000 miles, V8 305 vorec . Replaced fuel pump in tank (new), replaced fuel pump relay switch, replace fuse, check wiring and okay, ground wire is okay, but I still do not get no humming in the fuel tank, still does not start. It sems there is no power to the fuel pump tank. I ran out of ideas. What can I do.
The truck was running okay and suddenly stopped and had to tow home.[/quote:8cd0fc04ef]
At the fuel pump relay on the gray wire when you turn key to On it should have power and disappear within 2 secs. Check this out, No power its coming from the computer-it energizes the relay before it gets to the pump-
Sep 8, 2007 at 1:22 PM
  • 75,988 POSTS
Inbox :: Message From: tonydaniels To: rasmataz Posted: Sat Sep 08, 2007 5:32 pm Subject: fuel pump problems do you know where the computer located. There is a large box next to the fuse box next to the relays are located. Is this the computer. Its on the left side of the engine compartment, its sandwiched between the brake pressure modulator valve and front wheel speed sensor.
https://images.2carpros.com/forum/automotive_pictures/12900_97_Siverrado_truck_VCM_1.jpg
BTW check the oil pressure sending unit this the one that keeps it running when the engine fires up. Do this before you mess around with VCM Also you can bypass the fuel pump relay by using a jumper fuse wire from the battery positve terminal to the check connector fuel pump test connector-make sure key is Off-you should hear the pump. Good Luck
Sep 8, 2007 at 1:43 PM
  • 75,988 POSTS
I've received your PM and am glad for you.-When in doubt with wiring always perform a voltage drop on a loaded circuit before you condemn the component.
Sep 9, 2007 at 1:02 PM
Suggested Repair
With the key On, check the gray wire at the fuel pump relay for power that drops within about two seconds; no power means the VCM is not energizing the relay. Before condemning the VCM, check the oil pressure sending unit and do a voltage-drop test on the loaded circuit. With the key Off, a jumper from battery positive to the fuel-pump test terminal can confirm whether the pump runs.
Conversation Summary
A 1997 Chevrolet Silverado with a 305 Vortec suddenly stalled and would not restart. The owner replaced the in-tank fuel pump, relay, and fuse and verified the wiring and ground, but still heard no pump and suspected no power at the tank. The expert said the gray wire at the relay should briefly have power when the key is turned On, supplied by the computer, and located the VCM on the left side of the engine compartment. They advised checking the oil pressure sending unit before the VCM, optionally jumping the fuel-pump test connector with the key off, and using a loaded-circuit voltage-drop test before condemning parts.
