1999 Chevrolet Silverado 4WD Light
BARRY PUCKETT
I have a 1999 chevy z71 4wheel drive, 119,000 miles on it. It has a 5.3 v8 in it.
My question is the service 4 wheel drive light comes on until you cut truck off. Then it might be wks. before it comes on again. Any ideas?
When it is on you can not change to 4 wheel drive.
I have notice before the truck sounded like it was in 4 wheel but the push button said it was in 2 wheel.
thanks,
Barry
Sep 3, 2007 at 5:57 AM
CLY
  • 308 POSTS
My buddy had the same problem with his 99. The light finally came on and stayed on. He ended up replacing the encoder motor on the transfer case to correct the condision.
Cly
Sep 3, 2007 at 11:45 AM
Suggested Repair
Replace the encoder motor on the transfer case, which corrected the same intermittent service 4WD light and mode-shift problem on a similar 1999 truck.
Conversation Summary
A 1999 Chevrolet Silverado Z71 with a 5.3 V8 intermittently shows the service 4-wheel-drive light until the truck is shut off, sometimes for weeks at a time. While the light is on, 4WD cannot be selected, and the truck has sometimes seemed to be in 4WD while the button indicated 2WD. An expert reported the same issue on a 1999 truck and said replacing the transfer case encoder motor corrected it.
