Rear Differential
CHEVROLET SILVERADO
STLLWTR
I have an 83 chey K-10 with an 8-7/8 ring gear axel to remove the axel shaft you need to remove the differential pinion shaft. after I removed the lock bolt the shaft does not slide out any hints to this problem
Feb 20, 2007 at 8:30 AM
BOOTDOG
  • 665 POSTS
try pushing the axle inward and a c-clip should fall. it holds the axle in place so it won't slide out. once the clip is removed the axle should slide out with no problems.
Feb 20, 2007 at 9:21 AM
BOOTDOG
  • 665 POSTS
ok, did you pull out the 5/16 bolt that holds the the pin to keep the axles from sliding inward? can you take a picture of the inside of the differential so i can see whats going on? let me know
Feb 21, 2007 at 8:10 AM
STLLWTR
Yes I pulled the bolt out but the pinion shaft itself won't move even with a brass punch and 28 oz hammer driving it.
Feb 21, 2007 at 11:38 AM
BOOTDOG
  • 665 POSTS
when you say pinion shaft, do you mean the slide pin that you removed the 5/16 bolt out to keep the axles from sliding inward? because that should slide right out of the spider gears. i have never seen one froze up before. let me know.
Feb 22, 2007 at 9:26 AM
BOOTDOG
  • 665 POSTS
also make sure the bolt didn't break off inside the slide pin.
Feb 22, 2007 at 9:30 AM
STLLWTR
The whole bolt came out
Feb 22, 2007 at 9:34 AM
BOOTDOG
  • 665 POSTS
the only thing i can say is remove the hogs head out,( make sure that the shims that space the hogs head from the housing go back in the same spot, don't mix them up), and get it on a work bench and try getting more leverage to knock it out. if you have to, heat up the spider gears to expand the metal. it should come out.
Feb 22, 2007 at 9:50 AM
