1996 Chevrolet Cavalier CV Axle Breaks
CHEVROLET
BELL4374
My daughter ran through a giant pothole in her 1996 Cavalier a few nights ago, and broke the 2 CV axles.
The garage replaced the 2 axles, but one keeps breaking. They replaced it twice.
Once they got almost 1 mile before it broke, the second time, it broke in thier driveway.
The mechanic says it must be something in the suspension, but has no idea what the problem is.
Any ideas?
Jan 19, 2007 at 11:31 PM
BOOTDOG
  • 665 POSTS
i would take it to a frame shop and have them check to make sure nothing is bent. the axle could be in a bind.
Jan 19, 2007 at 11:40 PM
2CARPRO JACK
  • 11,533 POSTS
Check the outer wheel bearing. It might be bad and locking up causing the trans to break the axle
Jan 22, 2007 at 9:45 AM
BELL4374
Thanks to everyone for your help!
They actually found the problem today. It was a bent Torque Strut, and transmission mount.
They replaced these two parts, as well as replaced the cv axle again, and it seems to be just fine.
Finally!
Jan 22, 2007 at 10:16 AM
2CARPRO JACK
  • 11,533 POSTS
Sweeet
Jan 23, 2007 at 3:38 AM
Suggested Repair
Inspect the torque strut and transmission mount for bending after impact, and check the frame and outer wheel bearing for binding. Replace the bent mounts and the CV axle.
Conversation Summary
A 1996 Chevrolet Cavalier broke both CV axles after hitting a large pothole. Replacement axles failed almost immediately. Experts suggested checking the frame for a bind and inspecting the outer wheel bearing. The shop found a bent torque strut and transmission mount; replacing those parts and the CV axle resolved the problem.
