1983 Chevrolet K10 Stuck Axle Pin
Suggested Repair
Confirm the 5/16 cross-pin lock bolt came out completely and did not break off in the pin. Push each axle inward so the C-clip can drop, then slide the axle out. If the cross pin is still seized in the spider gears, remove the differential carrier, keep the side shims in their original positions, and drive the pin out on a bench. Heat the spider gears if needed so the metal expands.
Conversation Summary
The owner of a 1983 Chevrolet K10 with an 8-7/8 rear axle could not slide out the differential cross pin after removing the lock bolt, even with a brass punch and hammer. The expert explained that the axles are retained by C-clips and that the pin should normally slide out of the spider gears once the 5/16 bolt is fully removed. After the owner confirmed the whole bolt came out, the expert recommended removing the carrier without mixing up the spacing shims and using more leverage, and heat if necessary, to free the stuck pin.
