2001 Chevrolet Silverado No Fuel Pump Power
OCLAF
i replaced the fuel pump on an 2001 silverado, 4.3 liter, with 98k miles approximately...i dont get power to the pump? the relay appears good, i read in the manual, there is a fuze but cant find that? any ideas...? this is killing me! three days later the truck is still not running. could the PCM cause the lack of power, as the check engine light is on but last time i stuck the obd reader it said no codes stored?
Aug 27, 2007 at 4:02 PM
  • 75,988 POSTS
[quote:74950964fd="Oclaf"]i replaced the fuel pump on an 2001 silverado, 4.3 liter, with 98k miles approximately...i dont get power to the pump? the relay appears good, i read in the manual, there is a fuze but cant find that? any ideas...? this is killing me! three days later the truck is still not running. could the PCM cause the lack of power, as the check engine light is on but last time i stuck the obd reader it said no codes stored?[/quote:74950964fd]
Check the ECM B 20amp fuse-did you test the fuel pump relay to confirm its good. Turn key to On-at relay do have power at dark green and white-no power there and 20amp fuse is good and black wire is good to ground-I say its the PCM
Aug 27, 2007 at 9:19 PM
Suggested Repair
Check the ECM B 20-amp fuse and confirm the fuel pump relay is actually good. With the key on, verify power at the dark green/white wire at the relay. If that power is missing, the fuse is good, and the black ground wire is good, the PCM is the likely cause.
Conversation Summary
The owner replaced the fuel pump on a 2001 Chevrolet Silverado 4.3L and still has no power to the pump. The relay appears good, the fuse could not be found, and the check engine light is on with no stored codes. The expert advises checking the ECM B 20-amp fuse, testing the relay, and checking key-on power at the dark green/white wire; if the fuse and black ground are good but power is absent, suspect the PCM.
