Fuel pressure
FRANCEJEFF
  • CHEVROLET SILVERADO
I have a 1997 chevrolet 3/4 ton pu and replaced the fuel pump several times it has 205000 miles and now when I first try to crank it it acts as if the fuel pump is not working. If I leave the key on for 1 1/2 to 2 minutes it will try to start and after a few attemps of this procedure it will crank and run fine. Is there some sort of pressure switch or regulator that could be bad?
Monday, November 19th, 2007 AT 1:10 PM
Check the fuel pressure again, test the fuel pump relay and fuel pump/oil pressure sending unit. See below
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_17.gif
www.eautorepair.net
Monday, November 19th, 2007 AT 1:48 PM
