1999 Chevy Silverado Tail Lights Out
SHREKMO84
i have a problem with my tail lights brake lights and licence plate lights not working? i tryed the ground and then i tryed to turn my ignition on to check them now it does not turn and the horn goes off constantly. what should i do????????
o it is a 99 chevy silverado 80000 miles 4.6l
Feb 25, 2007 at 3:48 AM
CHEVY22
  • 1,375 POSTS
have you checked all fuses first ???? is there a hitch on the vehicle ??
Feb 25, 2007 at 4:34 AM
SHREKMO84
yes i did all fine it hase a bumper hitch
Feb 25, 2007 at 5:12 AM
CHEVY22
  • 1,375 POSTS
one last question are there any interior lights out and do you have a trailer hook up wiring harnedd
Feb 25, 2007 at 5:43 AM
SHREKMO84
no and yes but i unhooked it
Feb 25, 2007 at 1:52 PM
CHEVY22
  • 1,375 POSTS
why did you unhook it ??? the reason i ask thereis one wire that runs from the front to the rear that wroks the interior lights and the running lights , one brown wire goes from the switch splits to the front and rear and the interior light when it gets to the back it splts between the two taillights
Feb 25, 2007 at 1:57 PM
SHREKMO84
i got in an acident and it pinched the harness wires so it thoght that was the problem but it was not. there is that dumb spliter block in the rear that splits everything form the one main harness. but no lights are out it the cab
Feb 25, 2007 at 2:21 PM
CHEVY22
  • 1,375 POSTS
find and follow the brown wire , it does split off like i said but if you keep checking upstream you will find your problem
jim
Feb 26, 2007 at 12:09 AM
Suggested Repair
Fuses were already checked and are fine. Trace the brown running-light wire from the switch upstream through the rear splitter block, including the trailer harness that was pinched in an accident, to find the open circuit affecting the tail, brake, and license-plate lights.
Conversation Summary
A 1999 Chevrolet Silverado owner reported inoperative tail, brake, and license-plate lights. After checking a ground and turning the ignition on, the truck would not crank and the horn sounded constantly. Fuses were good, interior lights worked, and a bumper hitch and trailer wiring harness were present; the harness had been unhooked after an accident pinched it. The expert explained that one brown wire from the switch feeds the front and rear running lights and interior lights, then splits at the rear between the taillights, and advised following that brown wire upstream to locate the fault.
