2004 Chevy Silverado A/C Belt Noise
AARON560
I have a 2004 Chevy Silverado 1500 4wd with the 5.3l V-8 with about 50,000mi.
Problems with the A/C tensioner pulley/belt. It seemed the tensioner was weak. The unit was bouncing violently at rpm with the A/C on.With no A/C on, the A/C belt spun very smooth at any RPM. I replaced the tensioner AND belt with OEM parts from the dealership. The same thing is happening. Very,very smooth with no load on the compressor. Turn on the A/C and it is nice until the engine RPM goes above about 2500 Rpm. Then the pully starts going crazy and making a rackety noise for the moment until RPM is lowered. Is the compressor causing this ?
Thank-you,
Aaron Ankrom
Jul 19, 2007 at 4:11 PM
CLY
  • 308 POSTS
Aaron...
I have ran across this problem before and I did the samething that you did with replacing the belt and tensioner with the same results. I ended up having to replace the A/C compressor and the problem was gone..
Note: Don't forget to change the orifice tube when you do or have the compressor done....
Cly
Jul 19, 2007 at 9:58 PM
Suggested Repair
Replace the A/C compressor, and replace the orifice tube at the same time.
Conversation Summary
A 2004 Chevy Silverado 1500 with the 5.3L V8 had an A/C belt and tensioner pulley that bounced and made a rackety noise above about 2500 RPM only when the A/C was on. The belt ran smoothly with the compressor unloaded. Replacing the tensioner and belt with OEM parts did not fix it. The expert reported the same experience and said replacing the A/C compressor resolved it, noting that the orifice tube should also be replaced.
