well am back again with tranny not working still not shifting right i unplug the tranny and took it out for a test drive and it ran the same it even shift one time with the tranny unplug does this mean i need it rebuilt or is some thing stuck open i had it hook up on a computer it said shift solenoid not working right put new ones in still the same new valve body new wire harness for gm93 and up thats what he said any way i have 1996 chevy ext cab silverado new gaskets for the valve body and spacer plate this is a real pain all gears work great i been drive around in second because drive and 3 does not shift right you take of is shift fine the first shift when you hit 20 miles an hour starts to shifts it just rebs up and win you stop it shifts back down maybe new bands am lost it did shift when the new parts were put on for a block
Oct 13, 2007 at 2:12 AM
