2006 Chevy Silverado driver side window
73,000 MILES • V8 • 4WD • AUTOMATIC
JHARE89
My driver side window will go down but if i try to raise it back up it only moves a inch if that it stopped out of no where and i had to assist it back to the top i dont know if its the motor or regulator if anyone has any ideas please help me out
Sep 17, 2009 at 7:43 PM
QUAGMIRE86
  • 98 POSTS
That is a very common problem with Chevy trucks, especially on the driver's side since it gets the most use. It is so common, places like Advance Auto will more than likely have a new window regulator in stock. What the problem is on your truck is that the window motor and assembly lifts and lowers the window glass by means of a braided wire cable assembly. If you live in a northern climate and have ever had the window freeze (stuck) and tried to raise and lower the window, the cable becomes frayed and ends up wrapping around the good portion of the cable and eventually won't move up or down. You will have to replace the window regulator (motor and cable assembly). It is pretty easy to do. If you have "Vent-Visor" shades on your door, take it off the driver's door before you try to pull the glass out of the door...if not, the visor will get all scratched up...don't ask me how I know.
Sep 18, 2009 at 12:59 PM
