Voltage Problem
2005 CHEVROLET SILVERADO
35,000 MILES • V8 • 4WD • AUTOMATIC
KENNY782
  • 8 POSTS
Since I bought the truck the voltage meter on my dash always holds right in the middle at 14. But last week I noticed that it was moving around just a little, most people probably wouldn't have even noticed.
2 days later it was moving all over the place, depending on the engine temperture it could be anywhere from 11 to almost 16
Shortly after that my battery light came on in the dash. Later I found both my low beams blown out. The headlights where on at the time when I checked the next day it was both the bulbs not the fuses.
I tested it carefully with my multimeter:
Engine off: 12-12.1
Startup: 15.9-16.5
Mid warm up: 13.9
Fully warmed up: 12.5-12.9 on average but drops to 11 sometimes.
I'm no mechanic but I am a bit familiar with electric/electronics. I replaced the voltage regulator in the alternator with an identical one.
The engine starts up at 13.9 and slowly rises.
When the engine is warmed up it holds at 14.6
Oct 11, 2010 at 11:29 AM
  • 110,244 POSTS
This is normal because the PCM can vary the voltage to save gas and the battery from being overcharged.
May 13, 2021 at 12:50 PM
KENNY782
  • 8 POSTS
Thanks for the reply I really appreciate it.
Checked it again today same results 13.9-14.7 so it's at least consistent. Voltage held at 14.78 primarily.
With everything off today the battery gave me 12.7
With the engine off I turned the high beams and blower to full.
Voltage dropped to 10.9-11.2
Does that sound right?
I'm just trying to eliminate the battery if I can.
KENNY782
  • 8 POSTS
Some more research somebody said that 14.7 is actually the normally operating voltage on this truck. Can anyone confirm?
I also found someone who said that gm found the wiring harness to the alternator was faulty. It fixed the issue for a few months but then the alternator had to be changed anyway.
I just changed the regulator, I could change the harness tomorrow and maybe that will finally fix the issue and prevent any more damage.
What do you think of all this?
I was kinda on the same track but was just gonna clean all the terminals/connectors.
  • 110,244 POSTS
As far as the voltage, if you are getting 14.7 with the engine running, that sounds good. As far as the drop with the lights on / blower on... it sounds like that is low. Have you had the battery load tested?
KENNY782
  • 8 POSTS
Well I let advance run their test yesterday based on the new voltage readings I was getting.They said everything was okay at this point.
Thanks,
Kenny
