well my speedometer is actin up the problem is that it will read you doing 120 mph while actually you are going 55 mph the gauge will also not return to 0 or drop below 55. it will decrease a little apon breaking but the problem persists with the reading a higher speed and it just goes till it pegs out at the bottom of the gauge and it stays in its latest position when you shut the truck off, but when you crank the truck up it jumps down 5 mph the speedometer never returns to normal function and im not sure what is causing this i would apprieciate it if y'all could help me
Oct 7, 2009 at 7:18 PM
