2004 Chevy Silverado warning lights
KSUKID
Brakes problem
2004 Chevy Silverado V8 Four Wheel Drive Automatic
how do i make the brake warning lights turn off
Aug 21, 2010 at 2:17 PM
  • 110,251 POSTS
Is it the ABS light or the brake light? If the brake light, is the brake fluid full? Have you checked to make sure the park brake switch for the light is properly adjusted and the park brake fully returns?
Aug 21, 2010 at 3:15 PM
KSUKID
both lights stay on. fluid level is full . this is since i changed the pads.
Aug 22, 2010 at 9:33 AM
  • 110,251 POSTS
If both stay on, you need to have the computer scanned to see what is causing the ABS to stay lit. It sounds like a sensor problem. Make sure when you worked on it, by accident you didn't disconnect one of the sensors or damage the wiring to them.
Aug 22, 2010 at 4:29 PM
