2004 Chevy Silverado low range problem
68,000 MILES • V8 • 4WD • AUTOMATIC
BASSMASTER_21
I was pulling some logs with the truck yesturday,
i put it 4 low and hooked to a log, the back tires was the only ones that spun. The indacator showed it was in 4low. so i put it in 4 high then all 4 tire spun. How is that?
I did drive it fowards and backwards after i put it in 4 low, so the gears could line up.
Nov 18, 2009 at 3:19 AM
  • 110,248 POSTS
You need to remove the 4wd actuator and check to see if it is fully operational. I am assuming that when you were in 4 lo, the rear tires were in low gear, but as you said, the fronts didn't turn.
Nov 18, 2009 at 5:43 AM
BASSMASTER_21
Yes, the back was in low.
how easy is it to find the actuator?
can it be cleaned to work again?cause 4 high works everytime u want it to. thanks
Nov 23, 2009 at 3:53 AM
