2001 Chevy Silverado 4WD LOCKED IN HIGH WONT GO TO 2WD
2001 CHEVROLET SILVERADO
137,200 MILES • V8 • 4WD • AUTOMATIC
ASIA
i NEED TO FREE IT FROM HIGH TO 2WD TILL WINTER WHAT DO i NEED TO DO
Aug 25, 2009 at 5:34 AM
DR LOOT
  • 2,311 POSTS
usually it is the four-wheel drives switch on the dash that fail in this situation go to the junkyard and you can probably get another one for about $20.00 if it's not that the only other thing you can be is the actuator on the front axle you can remove the actuator and stick your finger in their and manually pull it out of 4 wheel Drive.
Aug 26, 2009 at 1:14 PM
