2004 Chevy Silverado Clunking sound in steering column...
2004 CHEVROLET SILVERADO
94,448 MILES • V8 • 4WD • AUTOMATIC
JNARLOCK
  • 5 POSTS
Occasionally at low speeds (or parked), the wheel is hard to turn, then there's a noise and/or vibration felt. The power steering fluid level is perfect (checked while running and not..) I can feel a clunk as though something is loose in the steering column when hitting bumps. I was told that those models need the "half shaft" greased in the steering column?? If so, where and how do I apply the grease? Could this be a result of an ailing power steering pump or something wrong with the steering assembly? Thank you.
Nov 28, 2008 at 1:35 AM
DENNYP
  • CAR REPAIR CONTRIBUTOR
  • 1,824 POSTS
You need to replace the steering intermediate shaft.
Nov 28, 2008 at 8:50 PM
DHD
  • 5 POSTS
There might be a recall, check with a GM dealer
Nov 28, 2008 at 11:39 PM
