2003 Chevy Silverado
CHEVIBOY
  • 2003 CHEVROLET SILVERADO
Noises problem
2003 Chevy Silverado V8 Four Wheel Drive Automatic
i have a loud popping noise coming from the front end of my truck. I happenes when I come so a stop, take off or turn I have replaced my tie rod ends and that did not help the problem. There is some leaking coming from the inside end to my cv axle past the bolting point.
Friday, December 4th, 2009 AT 12:05 AM
  • 109,885 POSTS
Usually a popping sound indicated a bad ball joint. As far as the leak, is it grease from a leaking CV boot cover or is it gear lube from a leaking axle seal.
Monday, December 7th, 2009 AT 10:52 AM
