2003 Chevy Silverado Defrost Only
FSEWELL
i have a 2003 chevy silverado 5.3liter it has 80,000 miles. my question is when i turn on the air it always blows out the defrost. will not stay where the control knob is. how do i fix this?
Sep 30, 2007 at 12:16 PM
BMRFIXIT
  • 19,053 POSTS
[quote:07d9a92d01="fsewell"]i have a 2003 chevy silverado 5.3liter it has 80,000 miles. my question is when i turn on the air it always blows out the defrost. will not stay where the control knob is. how do i fix this?[/quote:07d9a92d01]
Is it electronic if yes
need a motor
If not check you vacuum hoses
good luck
Sep 30, 2007 at 12:47 PM
DENNYP
  • 1,824 POSTS
[quote:7e1b0c409f="fsewell"]i have a 2003 chevy silverado 5.3liter it has 80,000 miles. my question is when i turn on the air it always blows out the defrost. will not stay where the control knob is. how do i fix this?[/quote:7e1b0c409f]I think you are having an issue with the mode door actuator.If you have a good scanner,you can compare the mode actuator desired counts to the actual counts.This will tell you if you have an actuator problem.
Sep 30, 2007 at 3:02 PM
Suggested Repair
If the HVAC controls are electronic, test the mode door actuator by comparing desired and actual counts with a scan tool and replace the actuator motor if they do not match. If the system is vacuum operated, inspect the vacuum hoses for leaks.
Conversation Summary
The owner of a 2003 Chevrolet Silverado 5.3L with 80,000 miles says the air always comes from the defrost vents and will not stay on the selected mode. Experts suggest a mode door actuator problem on an electronic system, confirmed by comparing desired and actual actuator counts, or leaking vacuum hoses if the controls are vacuum operated.
