2003 Chevy Silverado
KBLEDUC
  • 2003 CHEVROLET SILVERADO
Engine Performance problem
2003 Chevy Silverado V8 Two Wheel Drive Automatic
Have a 03 chev c2500 with a 6.0L
Runs roough - have done all the basic tune up stuff
plugs, wires, fuel filter, O2 sensors.
Was still missing on bank 1 (driver side) and smelled of raw fuel at exhaust. Have good compression.
Sent it to a exhaust shop and had both cat's replaced. Replaced plugs again on bank 1 (gas fouled). Runs better but still misses.
Checked fuel pump for pressure and volume and it checks out with specs. Injectors are pulseing normal.
Checked intake for leaks, replaced maf sensor when it coded.
Even check ecm for bad ground.
What am I missing?
Help please
Wednesday, September 3rd, 2008 AT 2:43 PM
RHALL77
  • 3,361 POSTS
D you check the fuel pressure regulator to see if it was leaking fuel. It is located on the fuel rail
Wednesday, September 3rd, 2008 AT 6:00 PM
KBLEDUC
It's dry
pulled vacuum line off and fuel pressure maxs out like it should.
Wednesday, September 3rd, 2008 AT 8:18 PM
RHALL77
  • 3,361 POSTS
I would have a injector balance test performed. This will tell you if a injector is bleeding down to fast when open causing a raw fuel condition
Thursday, September 4th, 2008 AT 7:10 AM
Related Oxygen Sensor Replace/Remove Content
