2002 Chevy Silverado
KRISSEPTEMBER
  • 2002 CHEVROLET SILVERADO
2002 Chevy Silverado V8 Four Wheel Drive Automatic
i got a code of PO327 & PO332. I replaced both knock sensors, pcm, jumper harness, & made new wiring & terminals from the pcm to jumper harness. What else can I do? Silverado 2002 z71
Wednesday, January 21st, 2009 AT 11:12 AM
RHALL77
  • 3,361 POSTS
What do you mean by jumper harness. Check and make sure your terminal tension is good at the connectors you made. Is it still setting these codes.
Wednesday, January 21st, 2009 AT 6:03 PM
KRISSEPTEMBER
The jumper harness is a small harness that connects to the knock sensors to the main engine harness.
All the terminals are new & have the correct amount of tension.
It has a cold air intake installed on it. Could that cause any issues?
It has an 11 inch lift also.
Thursday, January 22nd, 2009 AT 12:54 PM
RHALL77
  • 3,361 POSTS
Yes anything aftermarket can cause it. Take it back to factory and see if it fixes the problem. (Just the cold air intake)
Thursday, January 22nd, 2009 AT 5:26 PM
