Take it to a local auto part store such as AutoZone or O'Reilly Auto Part to have code deleted using the same scanner tool that gives you the codes. Normally they will not go out on their own just becuase you fix the issue, they have to be reset. You can also just disconnect neg. Cable on battery for 10 minutes or longer but this can also reset other things that you don't want reset, such as radio settings, clocks, etc.
SPONSORED LINKS
Wednesday, December 10th, 2008 AT 11:30 AM
