Just had similar problem with an 02 Camaro with a V6 engine. First, my cat converter was bad, partially blocking the exhaust. If you hear noises when you first start it up like a pebble in an empty can coming from the cat converter or exhaust, check that. When that went bad, the engine ran hotter, and my ignition coils went bad. Coils can still test good with an ohm meter and still be bad. When I changed my coils (after plugs and wires), the problem went away,
hopefully for good. They don't make coils like they used to. If that doesn't do it, I'd check the ignition module.
SPONSORED LINKS
Sunday, June 20th, 2010 AT 4:00 PM
