2000 Chevy Silverado
103,000 MILES • V8 • 2WD • AUTOMATIC
TAPPAN1
5.3 engine, on a cold start sounds like a lifter clicking but quits after a few minutes. been doing this for about two years. Use penzoil 10-w30 and change regularly. Engine runs fine. Please help
Mike Tappan
Oct 3, 2010 at 2:02 PM
  • 110,248 POSTS
The only way to be sure is to check if there is a loose lifter when it is cold. Steel expands when it gets hot, so that could cause the sound to go away.
Also, often times a slight exhaust leak can cause a tick when the engine is cold. Check the exhaust manifolds for leaks. You may want to use a stethoscope to see if you can hear exactly where the noise is coming from before taking things apart.
Oct 5, 2010 at 12:00 AM
