2002 Chevy Silverado Lifter noise
2002 CHEVROLET SILVERADO
88,000 MILES • V8 • 4WD • AUTOMATIC
NYGUY
My 2002 Silverado V-8 has a slight lifter tap upon startup if the truck has been off for over 3 or 4 hours. The noise is gone after idling for around 20 seconds. Oil pressure gauge show 40+ pounds. At no other time does the noise reoccurr.
Nov 14, 2009 at 6:56 AM
  • 110,244 POSTS
Make sure that the oil filter you use has an anti flowback valve. Also, there is a chance you have a lifter that is going bad and taking a while to pump up.
Nov 16, 2009 at 1:00 AM
WILLZ06JW
I fixed this problem on my truck by changing the Oil Pump Inlet Tube O-Ring. The lifters are the first part that don't get enough oil after this o-ring breaks down. All Chevrolet mid 2000s era 5.3L O-Ring fails around 150-190K.
Oil Pump Inlet tube O-Ring Replacement
https://www.youtube.com/watch?v=g1e3kx3mOMY
Nov 21, 2017 at 10:06 PM
  • 55,433 POSTS
Great addition to this thread! Please feel free to help out whenever you are on the site :)
Cheers, Ken
Nov 24, 2017 at 10:43 AM
