2000 Chevy Silverado
200,000 MILES • V8 • 2WD • AUTOMATIC
RKAUSTIN
The truck was used yesterday and had no problems at all. This morning leaving for work, it did not want to start--like the battery was about dead. After a couple tries it fired right up. On my way home from work, same thing happened. I work "on top of the mountain" and on the way down, the truck did not want to stop. With my foot off the accelerator and on the break, the rpm kept steadly rising. I drove it around the block to see if the incline was adding to the problem. Even while stopping at a stop sign, the rpm kept rising. When it was time to go, the truck seemed like it was driving itself. It spead up to 25mph without anything on the accelerator.
Aug 14, 2010 at 11:56 AM
  • 110,251 POSTS
Did the check engine light come on?
Aug 15, 2010 at 1:59 PM
RKAUSTIN
No. My mother-in-law is a parts manager at a Chevy dealership and she talked to a couple techs and they said it may be the Idle Air Contol Valve. Agree?
Aug 16, 2010 at 8:00 AM
  • 110,251 POSTS
It could be, but that wouldn't cause your battery to sound weak. Before replacing anything, make sure the battery terminals are clean and tight. You would be amazed what low voltage can do to electronics.
Let me know what you find.
PS: An IAC usually causes the RPM's to go up and down when they are bad (not idle).
Aug 16, 2010 at 4:30 PM
