will not go over 2000 rpm's sometime.
322,000 MILES • 6.6L • V8 • TURBO • 4WD • AUTOMATIC
ROGER1966
  • 5 POSTS
Driving down road and truck will loose power. Will not rev over 2000 rpm's. Can turn off key and let set for about 5 min. and will run ok for awhile, then it will happen again. No check engine light every comes on when it happens.
Oct 24, 2014 at 1:13 PM
MIKE H R
  • 3,094 POSTS
Sounds like a fuel problem. Have a 95 pontiac firebird and was doing the same thing, what you should do is check the fuel pressure. On our pontiac we had to put in a new fuel pump which it did not need and the pump screen. With the ethenal in the gas will clog up filters, We also used seafoam in the gas tank , it helps get rid of the crud in the gas tank
Oct 28, 2014 at 12:45 PM
