1999 Chevy Silverado Engine bucking
139,000 MILES • 6 CYL • 2WD • MANUAL
DMTSILVERADO
While driving my truck it seems to buck around 2000 rpm's. If I accelerate it quits doing this. In the mornings is when it is at its worse. I have replaced the fuel pump, plugs, wires, cap and rotor.
Dec 27, 2007 at 11:15 PM
DENNYP
  • 1,824 POSTS
remove the crank sensor and look to see if there are contact marks on the tip of the sensor. If there are, replace the sensor and install a shim on the sensor. The shims are available at your local dealership.
Dec 29, 2007 at 8:03 AM
