1999 Chevy Silverado alarms keep dinging, without key in!
ROY HUBECKY
  • 1999 CHEVROLET SILVERADO
Electrical problem
1999 Chevy Silverado V8 Four Wheel Drive Automatic 170k miles
After taking key out, the ding, ding ding keeps going off even if doors are shut. If I start the engine the ding ding goes off; but when I turn off engine and remove key it still goes off. Could it be ignition switch and can I remove the busser without still having a short or current draw? What circuit can I attack?
Thank you!
Saturday, March 14th, 2009 AT 8:31 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like aproblem with ehkey warning switch. The steering wheel needs to be removed to fix the problemUn less you have previous experience with air bags, I suggest you have a shop handle it. Otherwise you will also need a steering wheel puller to get the wheel off.
Tuesday, March 17th, 2009 AT 9:50 AM
ROY HUBECKY
Thanks for your suggestion, but after many hours of thought I kept spraying cleaner and w-d 40 with high pressure to clean out cylinder lock assy. I used a paper clip to jiggle the sensor at the bottom of the lock. IT Worked. Roy
Tuesday, March 17th, 2009 AT 12:19 PM
2CARPRO JACK
  • 11,533 POSTS
Good find.
Tuesday, March 17th, 2009 AT 12:40 PM
