2000 Chevy Silverado key cylinder
JEYKAL09
  • 2000 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 150,900 MILES
Lost keys had to move truck pulled old key cylinder tried to start m will turn over but wont bust off is there a security issue or?
Wednesday, August 25th, 2010 AT 8:24 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Most likely. Is security light flashing or solid in dash? Should be red light.
Wednesday, August 25th, 2010 AT 8:35 PM
JEYKAL09
The security light is flashing n th dash yellow
Thursday, August 26th, 2010 AT 1:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Normally, you would insert the key in
the drivers door, turn left, then right
to disarm and reset it. If yours is malfunctioning,
you can disable it for good by doing the following:
The FACTORY ALARM DISARM WIRE IS
lt. Green |-|in the drivers kick,
Also found in the purple plug of the BCM.
The BCM is located behind the drivers side
of the dash. The plugs on the BCM face
towards the rear of the vehicle.
Once Located, splice into this wire with
a simular guage wire, and put it to
a solid chassis ground. This terminates
the alarm functions entirely.
However, at this point, this car would be exceedingly
easy to steel, so I suggest you get an aftermarket
alarm system to protect it from here on in.
Thursday, August 26th, 2010 AT 7:57 PM
