1999 Chevy Silverado
SNOBRDRPRO
  • 1999 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 15,400 MILES
On my 1500 can I switch out the rear and front axles into a 2500 axles without switching out the rest of the drive train?
-thanks to all
Friday, April 3rd, 2009 AT 10:45 PM
JAMES W.
  • 2,394 POSTS
We have a lot of information at our fingertips, but unfortunately, interchange isn't part of it. Going from memory, the only thing that might cause a problem is spline size on the outboard joint. You can tell if they are different by comparing the nut size that holds the axle spline into the rotor hub. If the nut in the 2500 is bigger than the one in your 1500, chances are they won't fit. Also, you can check with your local salvage yard. They will have the interchange info you need and will be able to tell you. Hope this helps.
Saturday, April 4th, 2009 AT 12:53 AM
SNOBRDRPRO
  • 55 POSTS
Ok thanks. Could I use the front diff if it has the same gears?The front diff is what I really need
Saturday, April 4th, 2009 AT 1:24 AM
JAMES W.
  • 2,394 POSTS
As long as the ratio and the mounting are the same, go for it.
Saturday, April 4th, 2009 AT 1:48 AM
SNOBRDRPRO
  • 55 POSTS
Thanks a lot
Saturday, April 4th, 2009 AT 10:48 PM
