1997 Chevy Silverado Tail lights and wiper motor
1997 CHEVROLET SILVERADO
150,000 MILES • V8 • 2WD • AUTOMATIC
CHOPO51
My left front turn signal is blinking very fast. My left rear lights are not working at all. I found a bad bulb in the rear middle bulb and replaced it but it still wont work. The blown bulb kind of burned up the socket but it still looks to be making contact. What do you think?
My wipers dont work. If you move the wires around where they connect to the motor they will move but wont continue. I think the problem is with the wiring not the motor. What say you?
Aug 19, 2009 at 9:15 AM
DR LOOT
  • 2,311 POSTS
you will have to go to the junkyard and buy you a new socket even though it looks like it's still making contact it may be that take a test light, and make sure you have power. Now about your wipers remove the plug take a scribe and bend the contacts to make sure you're getting a good connection, if that does not help but you probably have a bad electronic board they are available at your local parts store.
Aug 20, 2009 at 7:12 AM
