1996 Chevy Silverado shifting into and out of 4 wheel drive
WLAFFEN
  • 1996 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 138,000 MILES
When trying to shift into 4H or 4L from 2H, the light just flashes for 2H. When shifting into 4L, the trasnfer case makes a normal clunk. However, the fron axle never engages. The fuse blows every time a shift into 4WD is tried. The fuse and the front axle 4WD actuator solonoid have been replaced but the problem remains. I am not sure of the next step and I would much prefer DIY fixes.
Friday, June 18th, 2010 AT 9:17 PM
02REDCAMARO
  • 65 POSTS
I heard of a guy who had a Chevy with a similar problem, the cause was a bad dash switch. Don't know if he was blowing fuses though. There isn't much else to work with here, unless you have a wiring harness/connector problem.
Sunday, June 20th, 2010 AT 4:35 PM
