1996 Chevy Silverado if mine is fuel injected how do i carb
85,280 MILES • V8 • 2WD • AUTOMATIC
CHEVYCOWBOY239
if my truck is fuel injected how do i go about changing it over so it is carborated and about how much approx. will parts cost?
May 11, 2009 at 10:31 PM
MMPRINCE4000
  • 8,548 POSTS
You probably don't want to hear this but you are far better off fixing the FI than going to a carb.
You would have to remove the intake manifold and replace with carb manifold, remove high pressure fuel pump and go to low pressure FP at around 5-6 psi vs 45-50 psi.
You would have no connections for MAP/MAF sensor, so check engine light would be on all the time.
Probably your best bet is to go to Summit racing or Jegs for a kit. Edelbrock makes conversion kits, I believe. Check with tech departments at Summit or Jegs for details.
May 11, 2009 at 11:39 PM
