I am having performance problems after I had my fuel pump replaced. The truck doesn't want to stay at an idle it will die. when its taken out on a test drive the trans won't shift out of first gear. I have replaced the fuel pump & filter, air filter, plugs & wires,cap & rotor, module & pick up coil and wireing harness for the Ignition switch. The mechanic said I may need a tranny flush or a throttle body over haul. but as I said before the truck ran perfectly fine prior to him working on it.
Feb 18, 2010 at 6:18 PM
