I am having a problem with my truck when I first go through the gears. It seems like it is missing unitill I go through the gears the first few times. Once I go through about three or four times it seems to even itself out and run fine. I have already changed the plugs, wires, cap, rotor, fuel filter, and also the air filter. I thought it might just be some bad gas or possibly the injectors so I have put some injector cleaner in the fuel tank but I still have had no relief. Not sure what the problem is. I was wondering about the timing but I figured it would be doing it all the time if it was the tming. Also do you think it could be the fuel pump?
SPONSORED LINKS
Monday, September 22nd, 2008 AT 9:04 AM
