1994 Chevy Silverado wants to stall when first starting out
GARY66
  • 1994 CHEVROLET SILVERADO
  • V8
  • 14,500 MILES
Changed rotor and cap changed spark plugs and wires. Cleaned carburator. Whats next fuel filter?
Monday, August 10th, 2009 AT 11:04 AM
Check the fuel filter, test the coolant temperature sensor and clean out the idle air control valve to include the EGR and PCV valves.
Monday, August 10th, 2009 AT 3:25 PM
GARY66
I changed fuel filter pcv valve temperature sensor an cleaned idle air control valve what parts do I change next. Still wants to stall at stop sighs until truck warms up good.
Tuesday, August 11th, 2009 AT 1:43 PM
Have you clean out the EGR valve? If not do so and then test the TPS and MAP sensors.
Tuesday, August 11th, 2009 AT 1:45 PM
