1994 Chevy Silverado harmonic balancer
ADAM1375
Engine Mechanical problem
1994 Chevy Silverado V8 Four Wheel Drive Automatic
How to change a harmonic balancer on a 1994 k1500 4wd 5.7L Engine?
Sep 17, 2010 at 5:05 PM
  • 110,246 POSTS
You will need to remove the belt, pulley that is attached to the balancer, remove the center bolt that connects the balancer to the crank, and then with a wheel puller, remove the harmonic balancer. It will have a keyway so make sure when you replace it, you line it up.
Sep 18, 2010 at 4:29 PM
