Symptoms you have described do sound like a faulty IAC valve. If the diagnostics showed the IAC valve as being the culprit then inspect the IAC valve wiring to ensure it is connected properly. If wire connection is loose then reconnect it and see if it helps. If it is connected already then disconnect the IAC valve and listen to the RPMs. If the engine tries to stall after unplugging IAC valve then it is working. If the RPMs stay the same or get better even, this indicates a faulty IAC valve.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Tuesday, February 17th, 2009 AT 11:14 PM
