This engine does not have a 02 sensor, it does have
a knock sensor, ect sensor, pcm & map sensor with a
ecu[electronic control module]
I would like to increase the hp, is it possible to change or reprogram the ecu unit and also change
the map sensor if needed to be compatible?
I am hoping to gain 40-50hp by changing the heads
and cam also keeping the compression ratio at 9.3:1
If I have to change to a different ecu unit, are there
any adapters available to make it somewhat simple.
I don't have a problem donating $$$ if you can
give me the info I need to do this!
Thank you Mike Kennedy
Wednesday, September 30th, 2009 AT 10:09 PM
