You will have to take the door completely apart, because the window regulator is riveted to the inside panel you'll have to unbolt the whole panel when you have the panel on Bolton you can slide backwards and roll it off the window, make sure you take out your window with duct tape so it does not fall down, then there are three special bolts on the motor and be very careful taking it apart, the easiest thing to do is just go to the junkyard and remove the whole center section of the door it will probably cost you about $35
SPONSORED LINKS
Thursday, August 20th, 2009 AT 1:42 PM
