2001 Chevy Silverado Passenger Window
BOOMER617
  • 2001 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 234,000 MILES
My passenger window stopped working I can hear the motor working but the window won't roll down. It goes up but if I hit the down on the switch the window will slide down gradually. I also can't figure out how to get the door apart.
Sunday, September 27th, 2009 AT 10:13 PM
JEEPFAN
  • 135 POSTS
When you push the switch and hear the motor do you hear anything like grinding or crunching? Alot of times these window regulators use a small cable to roll the window up and down and sometimes that cable will get tangled and keep the window from working properly. To take the panel off pry the lock out of the panel and there is a 7mm screw behind it also another 7mm screw right under the front of the handle you hold to close door and another 7mm screw on very bottom of door oonce all are out the panel slides straight up and off
Monday, September 28th, 2009 AT 3:02 PM
MARZEPEDA
What are the steps to replace this? Purchase a new cable or replace the whole moter? Is there a digram some where? I googled it but nothing came up.
Thanks,
Zman
Friday, October 9th, 2009 AT 12:03 AM
JEEPFAN
  • 135 POSTS
Disconnect the negative battery cable remove door panel
and remove the bolts holding the regulator in and remove the bolts holding glass to regulator remove door glass from door or tape it up in the all the way up position disconnect plug from motor work the regulator out of the opening.
The regulator sometimes is only sold with motor and regulator as one
Friday, October 9th, 2009 AT 12:29 AM
MARZEPEDA
Thanks for the info. If the cable split can I just replace the cable or it all comes together?
Thanks again,
Zman
Friday, October 9th, 2009 AT 10:04 AM
JEEPFAN
  • 135 POSTS
If the cable split you have to replace the entire regulator
Friday, October 9th, 2009 AT 12:04 PM
