engine stalling problems?
15,500 MILES • V8 • 4WD • MANUAL
SARGENTWOODY
  • 20 POSTS
Alright.So, I've had this idling problem lately with my truck.It idles at about 550-600 rpms..but every few seconds it will drop down to 450-500, sorta like it wants to stall, then go to normal and so on.Any ideas? Thanks.
Mar 6, 2008 at 11:19 PM
BLACKOP555
  • 10,386 POSTS
unhook the IAC module does the problem go away? This is common when you have a vacuum leak or the throttle bore needs to be serviced here are three guides to go over when fixing the problem.
and
https://www.2carpros.com/articles/stall-at-idle
and
Mar 14, 2008 at 9:35 AM
SARGENTWOODY
  • 20 POSTS
yes, that fixed the problem...i started it and it idled like crazy good...what now, i can't just have that unhooked can i? i replaced that part not too long ago...like 5k miles ago when i had my fuel pump problem. after i replaced my fuel pump and iac and tps is when it started idling weird...so ... what now?
Mar 14, 2008 at 10:41 AM
BLACKOP555
  • 10,386 POSTS
ah now were getting somewhere, sounds like you may have gotten the wrong IAC module and it isnt funtioning properly! if you still have the old one try that.
if that doesnt fix it you may have a bad PCM but i really doubt that.
Mar 14, 2008 at 11:06 AM
SARGENTWOODY
  • 20 POSTS
alrighty...i dont think i have the old one..i may, i'll look, if not, i'll go get a new one and see if that fixes it.
ill let you know what happens...thanks!
Mar 14, 2008 at 12:20 PM
SARGENTWOODY
  • 20 POSTS
i shouldn't say it idled good...but it definetly idled high..about 1000 rpms...and i dont have the old part, which sucks because it's a 75$ part. i guess ill try replacing it. hopefully the parts place gave me the wrong part. HOPEFULLY
Mar 14, 2008 at 4:42 PM
BLACKOP555
  • 10,386 POSTS
if that isnt it you may have to take it in and have them try to reprogram the IAC and PCM or replace the PCM.
is your throttle body clean?
Mar 15, 2008 at 1:10 AM
SARGENTWOODY
  • 20 POSTS
what is the PCM?
Mar 15, 2008 at 3:10 PM
BLACKOP555
  • 10,386 POSTS
Powertrain Control Module.
it is what controls all the vehicles systems.
Mar 16, 2008 at 12:45 AM
TIGERZ
i have the EXACT same problem. i have a 1993 k1500
it just all of a sudden started idling like that. the engine also hesitates a little sometimes.
i replaced my air filter(K&N), coil(MSD), new plugs(OEM), and the EGR Valve. i have more power but it still hasnt fixed the problem.
let me know if you pin pointed what is was. i dont want to keep throwing parts at it.
Mar 20, 2008 at 6:18 AM
TIGERZ
Idle Air Control Valve was the problem
or IAC
the old one had all this nasty grease and carbon build up. replaced it and it idled like a champ.
$46.00 at autozone
Mar 27, 2008 at 10:35 AM
BLACKOP555
  • 10,386 POSTS
glad the IAC module was the problem not something harder to diagnose :D
Mar 28, 2008 at 12:19 AM
TIGERZ
looks like my response was a bit premature. im still having the issue. and i still have an acceleration issue sometimes. the motor just bogs and then kicks in after a second.
Mar 31, 2008 at 12:54 PM
BLACKOP555
  • 10,386 POSTS
check your TPS sensor resistance at closed throttle and then WOT. then check it as throttle is slowly opened, should be very steady.
can you have it checked for a vacuum leak? take a can of carb cleaner and spray around the EGR valve, the intake manifold, IAC module, throttle body and all vacuum lines.
Mar 31, 2008 at 1:32 PM
