1991 Chevy Silverado need to know how to take out transmiss
BRAD1024
  • 1991 CHEVROLET SILVERADO
Transmission problem
1991 Chevy Silverado 6 cyl Two Wheel Drive Manual
the transmission in my truck went out and I tried to pull it out to put in a new one but I cant get it out. There were 6 bolts holding it to the motor, 3 on each side I took those out and took out the part that connects to the clutch and took out the started and I still cant get it out. It has a 4.3l v6 and a 5 speed. Im pretty sure its a mg5 but not positive.
Saturday, April 25th, 2009 AT 5:00 PM
  • 110,053 POSTS
It sounds like you have everything loose. Could the dial pins be corroded and holding it?
Sunday, April 26th, 2009 AT 12:10 PM
BRAD1024
Im not exactly sure what the dial pins are. I kno sum stuff about cars but im not great with them. Im using a motorcycie jack and have a ratchet strap holding it to the jack and I put a rope on the jack and pulled and it still wouldnt come out
Sunday, April 26th, 2009 AT 1:02 PM
  • 110,053 POSTS
The dial pins are short steel rods (maybe 1/4") that are between the trans and the engine. They are used to align the two during assembly. They can get tight, but it sounds like you are trying hard enough to pop them loose. Are you sure there isn't one more bolt at the top center? Does the trans move at all from the engine?
I just spent 10 minutes trying to find a picture of the bellhousing and can't. There are three different transmissions it could be. None of what you mentioned. Every one says to remove the top two bolts first. Make sure there isn't one hiding under wiring or something.
Sunday, April 26th, 2009 AT 8:45 PM
Related Transmission Clutch Content
How to Check Your Clutch Operation?
VIDEO
