You cannot set the timing accuratly without a scan tool capable of setting the timing on a computer controlled engine. Also, if it has a crankshaft position sensor, the computer should have a crank relearn proceedure done. A trip to the dealer is the only way to properly have the timing set and the crank relearn proceedure done.
SPONSORED LINKS
Sunday, April 19th, 2009 AT 9:56 PM
